Wells.Strength
I installed line lock on my 95, zero success, I figured maybe the ABS was messing with it or I got a cheap solenoid. Got a summit solenoid, deleted the ABS, still doesn’t hold. Apply the brakes by foot, holds fine, press the button and let go of the brake and it doesn’t hold, if I pump them it attempts to grab a hold but won’t even hold at an idle, apply more brake pressure with the button pushed helps a little more. Anybody have a similar issue and have a solution? Seems to me if the brakes hold, and the solenoid is just blocking back flow of fluid and pressure it should hold… not the case here.
