look at this
jwhisl
Oklahoma
I just got my car tuned for the split port swap and this is how it idles. I had the o2 sensors turned off being I found my cats are hollowed out. What do you guys think
DeepList
Administrator
Admin
Auburn, IN
:dontknow:
FivepointSlow
Enfield, CT, USA
Crappa-talk strips out the emoticons also? Ppffttt..... :deeplist:
Yea I really wish they didn't do that... I usually use the desktop version via Safari but my school wifi is poo so I use tapatalk while I'm in class lol
Sent via swagPhone 5.0 using Tapatalk
J
jwhisl
Oklahoma
Ok so apparently I cant post media in my phone browser. I only had 2 o2 sensors when I bought the car. I can't find the plugs for the other two.
Orange 94
Alberta Canada
So you are using the 2 front oxygen sensor correct? How old are they?
Who tuned it? When?
J
jwhisl
Oklahoma
I think they are the front two... I just had it tuned 4 days ago by a local guy. I opted out of the dyno for now. It holds the idle at 2k at lights and in between shifts
Orange 94
Alberta Canada
Okay, thats fine then. If you have no idea how old they are I would suggest changing them.
How did the car run after the tune? Could it be the actual tune itself?
J
jwhisl
Oklahoma
It was running smoother before the tune. I know the guy adjusted the Idle and advanced the timing. He turned off the o2 sensors. I might have him turn them back on
Orange 94
Alberta Canada
well if it was running better before the tune then its likely something the tuner did?
chris91
Cincinnati, OH
He probably turned off the rear o2's. With no cats or hollowed out cats they wont get a correct reading and throw a cel.
Orange 94
Alberta Canada
^this
I don't run rears, never have. But you do need front ones and if they aren't good it will cause you all sorts or problem.
The tuner does need to turn off the rears if you're not using them or you will get CEL like chris said.
J
jwhisl
Oklahoma
Alright Just got back from the tuner. Previous owner mover the front o2 sensors to the bottom side of the headers so they were hard to see. I had him make sure they were turned off and he made some adjustments to the tunes. After 2 more burns its running almost perfect. Even feels like it picked up a little more torque. He admitted to me that he was using a premade split port file with small adjustments and he is now going to make me a full custom tune. He also told me he would give me $50 off on the dyno run so I'm going to dyno tune it and post some numbers (even though they won't be as impressive as Orange's) ;)
fiveohwblow
Thats good news. I will have to check out your build thread to see what all you have going on...
J
jwhisl
Oklahoma
Thanks! Build was on the back burner for a month or so. Engine is almost fully assembled now. Should put down 320ish at the wheels
marktuck99
