Low Coolant light
jpajkos
Whats up guys. Acouple days ago my top radiator hose went. I replaced it and filled it up with fluids. When im at idle my low coolant light stays off but when I drive it comes on. I repeatly check my fluids and it says its has a enough. I checked for some sort of bleeder valve to see if there was air in the system but couldn't find one. Is there a way to turn the light off or am I missing something? Thanks
scarface
Guest
clean the gunk out of the overflow tank. Mine did that when I first got it, Once I removed all the crap it stopped.
DropTopPony
South Jersey
i have to keep my overflow tank almost full or my light comes on... turn your heat on and run the rpm's up to like 3k...oh take off the cap...this will get the air out of your system if you have any...hold it for a few minutes until the tstat opens and everthing is circulating.
Lightning Struck
my 98 did the exact same thing
Vmarch
