I have a 95 GT convertible with a 460 mach system I just want to replace the speakers. Dose anyone know the specs of the 2 amps in the trunk thanks
I can't remember what over rated numbers they gave them myself but I am sure someone does. I know the tweeter is a 4 ohm which is easy to find but its an odd 2.5" size that normally requires that a baffle be made to mount a smaller tweeter in it. The woofer is always the harder part as if I remember correctly its an 8 ohm 5 x 7" woofer. Not many speakers to choose from that are 5 x 7" and fewer(zero really) that are specifically just a woofer that will play the low range out the amp will feed it. If you have replaced the deck its much easier and better sounding to bypass the amps and just power your speakers straight off of the aftermarket deck. The mach amps over the past 5-10 years have been turning up more and more as power drains as they do not shut off and kills the battery.
