Mach460 Head Unit Replacement
ck5.0
I wanted to start a thread with all of the info we have on the harnesses adapters and such for Mach460 head unit replacement.
Each picture kinda explains itself. Each one of these are from crutchfield. Basically if you had each one of these (not all of them are needed but nice to have for the intall) then you should have no problems installed an Aftermarket head unit in your Mach460 system.
SORRY UPGRADING FORUMS, ATTACHMENT WAS ERASED, YOU NEED TO REUPLOAD!
C
ck5.0
Audiooutfitters.com also sell two different wiring harnesses for the Mach460. One actually takes the speaker levels and converts them to RCA to plug into your head units front and rear RCA outputs. It sells for around 29 bucks. The other is basically the same as the schosche adapter from crutchfield but does not come with the gain control and it works just fine. It it the least expensive way to go for about 5 bucks.
Br1anh
