So here is the progress now: After getting my car back from the "mechanic", my brake lights/blinkers stopped working. The mechanic insist it wasnt his wrongdoing "probably just a fuse". Popped the fuse and it was blown, ok replaced it and there problem solved. paid him for his work. Went out to eat, and again my brake lights and blinkers dont work. Fuse blown again. and again. and..again. Went online and found that others had issues with this when installing a Steeda adjustable kit. Turns the stock quadrant has this rubber thing and it protects the wire from being rubbed the wrong way by the clutch pedal. So I stuck some duct around around some areas to see what worked. I put duct tape around the upper part of the pedal and boom it worked, for a little bit till it blew again. So i went looking for it and found it. Found the wire, taped it and moved it. No more blown fuses (knock on wood). 80 miles later my brand new clutch began slipping..great. Called back the dude, and he said it was the clutch and not his work. I told him no it wasnt adjusted right, he said it was, and to bring it over and hell check it out. But it was slipping sooooo dam much i couldnt even drive it! He said he will come over my house that saturday and he will fix it. So i started adjusting the cable myself from the firewall, it got waaaaay better. Took it to work and bam, slipping hard again. Called him back to tell him im coming over now. 5 missed calls and a voicemail and no call back. So i said f that guy. Got under my dash and saw that the cable was on the hook closet to the floor. GREAT. I crawled under my car and stuck 2 wrenches into the tranny and pulled the clutch fork forward and took out the cable. Put the cable end on the quadrant hook closed to the top, crawled back under and connected it to the clutch fork. and guess what?! NO MORE SLIPPING!!!!. Glad i caught it on time and it didnt mess up my dam clutch. One thing the "mechanic" did good was telling me my water pump is leaking, thermostat housing is leaking, and radiator is broken/leaking.
