Madd Motorsports Time Attack and Autocross Build
B
B.mad
Preferred Vendor
SoCal
Do people still use this? After disappearing, thought maybe i would make an appearance.
B
B.mad
Preferred Vendor
SoCal
And all my pictures are gone because Flickr decided to sell out and be a POS.
evilcw311
Most Evil Member!
Louisville, KY
One of these days you people will learn to use Tapatalk and not have these issues. [emoji38]
evilcw311
Most Evil Member!
Louisville, KY
I recently switched to imgur, I like it.
[emoji38]
B
B.mad
Preferred Vendor
SoCal
I used to use tapatalk, but my fat fingers created too many typos. Took 3 min to write a sentence after rewriting it 40 times..
B
B.mad
Preferred Vendor
SoCal
Well I guess I can start the updates. Since my car came back from GTR, it sat in the garage. Until I moved houses, where it went 5 miles away, and sat again..
Sent from my SM-G960U using Tapatalk
B
B.mad
Preferred Vendor
SoCal
Then I sold the oil cooler setup to Cody.
B
B.mad
Preferred Vendor
SoCal
Also starting using the car to mock up customers lights.
B
B.mad
Preferred Vendor
SoCal
Been driving the car for weeks at a time since I live a lot closer to work now. Car runs great. Needs a tune up, needs exhaust leaks fixed, and vacuum leaks. Also have a power drain somewhere as my battery keeps dying. And I have a lot positive terminal that needs to get fixed. Otherwise, it runs good. Still has power. Cant drive it a lot because of no lights and loud exhaust. But I tried to get it out there.
Oh I had one headlight. But it's for a customer [emoji3]
B
B.mad
Preferred Vendor
SoCal
Car is at GTR HiPo to get the issues sorted out. So toom the time to get some work in for its return.
B
B.mad
Preferred Vendor
SoCal
I had some headlights cut a while ago, and had these projectors etched over a year ago. These are the Morimoto MD2S 4.0 etching with "Madd Retros" and a damaged checkered flag.
The headlights chrome has been stripped and projectors adjusted. And since my logo is the G37C-R shroud, it was a no brainer to use that as my shroud. The only problem, this shroud is MASSIVE. It wont fit..without a fight.
A comparison pic of what is left if the shroud.
B
B.mad
Preferred Vendor
SoCal
Got them cut to size. Fits pretty snug. Also cut open a DEPO side marker.
B
B.mad
Preferred Vendor
SoCal
Dechromed the housing and shrouds. Sanded them with 600 grit sand paper. Cleaned them with a 2:1 alcohol/water solution and wiped clean with a cloth. This removes lose debris and any oils from human hands. Then grab the heat gun to dry off an excessive water, and warms up the parts for better adhesion. After that, spray it with 3 coats of primer. Let them dry overnight. Next morning, take them out, go over it with 1000 grit to smooth out the surface. Then again clean with solution, wipe clean, and heat it up to dry and to make the paint stick better.
B
B.mad
Preferred Vendor
SoCal
Decided to paint the shrouds gun metal grey. The paint leaves an almost matte finish once it dries.
B
B.mad
Preferred Vendor
SoCal
I wanted to mount a halo behind the shroud so it lights up the plastic insert but there wasnt a halo with a big enough inner diameter to clear the projector, and with an outer diameter that fit inside the reflector. So I decided to paint the shroud inserts satin black. And the reflector was painted Gloss Black.
I didnt want the shroud to have a matte finish. So I sprayed 2 coats of clear. Sooooo much better. You can actually see the metallic.
The gloss black comes out glossy. But it's not good enough for me. So I sprayed 2 coats of clear. Much better and shinier.
B
B.mad
Preferred Vendor
SoCal
Next, I took the projectors a part and removed the shield from them. Taped up the solenoid and the hinge. Scuffed it up with 600 grit and sprayed it with Engine Enamel in Dayonta Yellow.
This creates a passive demon eye. The yellow will shine through the lens, just as a demon eye, but with no light! It will be shown at all times as long as no other light is shining through. Looks pretty cool huh?
bs.austin.tx
