lutter94
Went down quite a rabbit hole lately. Ended up buying 2 MeterMach MM-1 units, along with an Autometer 2242 Oil Pressure Sending Unit, and a AEM 30-2013 Water Temp Sensor. The oil pressure adaptation has already been explained by Mark Olson, and TechnoVersions has already posted the whole process for this. I'm attempting to take it a step further and make my coolant temp gauge more understandable/accurate. Apparently his v1.2 included the OEM temp sensor, but v1.3 had it removed. The aftermarket sensor has a better output curve to calibrate to. Will see how it goes. I hate not knowing how hot it really is, esp after having the needle off a couple times with gauge face swaps.
Mark's write up
https://www.technoversions.com/MeterMatchMustangHowTo.pdf
I think I settled on the second cal, the tough part is getting a 4 point cal to come close to the calibration curve (it isn't linear).
Mark's write up
