MF Kustoms Terminator X Install - Ignition plug?
emjohn43
On my 1995 Cobra - I'm installing a Terminator X and using the MF Kustoms adapter. Anyone use one of these setups here? If so...read on...
I've got it all hooked up, but I can't find where the 'ignition' plug goes? It does not look like the one on my OEM distributor, and does not look like the one on the ignition module in the passenger fender.
I'm sure I am simply overlooking something obvious - but it isn't coming to me. Where should I be looking?
Thanks!
94IndyPace
Did you ask on the Holley terminator X group on Fakebook. Danny/MF Kustoms will answer. I’m assuming it should have his adapter harness
E
emjohn43
I haven't ... let me pop over there and do that too.
From what I'm seeing it looks like I need to get a Holley dual-sync distributor....but nothing said anything about that being needed in all the 'plug and play' videos and instrucitons I read.
94IndyPace
Don’t need to, I’m using a stock style distributor in mine. I made my own harness off his wiring diagram.
E
emjohn43
He actually just responded to a direct message in facebook - he said the ignition plug is not used unless going to a dual-sync distributor. Seems odd, but heck, he designed it so I'll trust him.
I'll finish the install tomorrow, just have to find a place for the external MAP sensor and put in the o2 sensor, and I guess it should be ready to start after putting the base tune from the computer to the terminator.
Fingers crossed!
If you HAVE to have the dual sync I got one a while back for if/when mine goes bad and I have never used it.
94IndyPace
Fingers crossed!
Good to know. I didn’t use his kit, I used the 550-937 universal kit.
qzxo_oxzp
