1994: Model Price Weight Production Coupe $13,355 3,055 42,883 Vert $20,150 3,193 18,333 Coupe GT $17,270 3,258 30,592 Vert GT $21,960 3,414 25,381 Year Total 123,198 *Ford includes 5,009 SVT Cobra coupes and 1,000 convertibles Code Engine Intake Power Tranny 4 232CID V6 EFI 145 M5, A4 E 302CID V8 EFI 215 M5, A4 D 302CID V8 EFI 240 M5 1994 SVT Cobra Model Price Weight Production Coupe $20,765 3,365 5,009 Vert $26,845 3,567 1,000 Year Total 6,009* *SVT reports color breakdown for 2,908 Rio Red coupes, 1000 Rio Red convertibles, 1,795 Black coupes and 1,306 Crystal White coupes. Code Engine Power Tranny D 302CID V8 240 M5 1994 Saleen S-351 Model Price Production Coupe $34,990 30 Vert $40,990 14 Coupe SR $45,990 2 Year Total 46 Code Engine Power Tranny 4 232CID V6* 145 M5, A4 E 302CID V8* 215 M5, A4 N/A 351CID 5.8 371 M5 V8** N/A 351CID 5.8 480 M5 V8 Super** *Removed from Saleen S-351s during conversion **Actual powertrains used in S-351 production 1995: Model Price Weight Production Coupe $14,330 3,077 * Vert $20,795 3,257 * Coupe GT $17,905 3,280 * Vert GT $22,595 3,451 * Coupe GTS $16,910 3,246 * Year Total 185,986 *Ford reports total production of 137,722 coupes, 48,264 convertibles, 4,005 SVT Cobra coupes, 1,003 Cobra convertibles and 250 Cobra R models Code Engine Intake Power Tranny 4 232CID V6 EFI 145 M5, A4 E 302CID V8 EFI 215 M5, A4 D 302CID V8 EFI 240 M5 C 351CID V8 EFI 300 M5 Cobra R 1995 SVT Cobra Model Price Weight Production Coupe $21,300 3,365 4,005 Vert $25,605 3,587 1,003 Coupe R $35,499* 3,280 250 Year Total 5,258** *Price does not include gas guzzler tax ** SVT reports color breakdown for 1,447 Rio Red coupes, 1,433 Black coupes, 1,003 Black convertibles and 1,125 Crystal White coupes. 1995 SVT Cobra R Code Engine Power Tranny D 302CID V8 240 M5 C 351CID V8 300 M5 1995 Cobra Removable Top Only 499 of the special tops were made for the 1,825 option 1995 Saleen S-351 Model Price Production Coupe $34,990 89 Vert $43,990 43 Coupe SR $59,990 7* Year Total 139 *Output includes 6 competition models Code Engine Power Tranny 4 232CID V6* 145 M5, A4 E 302CID V8* 215 M5, A4 N/A 351CID 5.8 371 M5 V8** N/A 351CID V8 480 M5 V8 Super** *Removed from Saleen S-351s during conversion ** Actual powertrains used in S-351 production Reference from Mustang Field Guide By: Brad Bowling
How does this compare? Additional info...ET times can & did vary. Specifications: Year: 1994 Make: Ford Model: Mustang GT Base Price: $17,000 USD Origin: Detroit, Michigan, USA ¼ mile: 15.0 Seconds 0 - 60 MPH: 6.6 Seconds Gas Mileage: City: 18 MPG / Hwy: 26 MPG Position: Front Longitudinal Configuration: Cast Iron, V8 Valvetrain: OHV, 2 Valves per Cyl Displacement: 302.0 CI / 4950 CC Power: 215 BHP / 160.3 KW @ 4200 RPM Torque: 285 FT LBS / 386 NM @ 3400 RPM Redline: 5900 Bore: 4.0 IN 102 MM Stroke: 3.0 IN 76 MM HP/L: 43 BHP per Liter HP/LB: 15.8 LBS per BHP Drive Wheels: RWD Curb Weight: 3405 LBS 1544.2 KG Steering: Rack & Pinion Materials: Unit Steel Front Brakes: Vented Discs w/Vacuum Assist, ABS Front Brake Size: 10.8 IN / 274 MM Rear Brakes: Vented Discs w/Vacuum Assist, ABS Rear Brake Size: 10.5 IN / 267 MM Front Tires: 245/45ZR17 Rear Tires: 245/45ZR17 Front Suspension: MacPherson Struts w/Lower A-Arms, Coil Springs, Telescopic Shocks, Anti-Roll Bar Rear Suspension: Live Axle w/Trailing Arms, Coild Springs, Telescopic Dampers, Anti-Roll Bar Transmission: 5-Speed Manual 1st Gear Ratio: 3.35:1 2nd Gear Ratio: 1.99:1 3rd Gear Ratio: 1.33:1 4th Gear Ratio: 1.00:1 5th Gear Ratio: 0.68:1 Final Drive Ratio: 3.08:1
