MUSTANGMURLEY'S 1996 GT 4.6L 2V SOHC SN95 BUILD
mustangmurley
mustangmurley
FORT WAYNE, IN
Fixed a vac line tonight. Ordering new rubber next week.
mustangmurley
mustangmurley
FORT WAYNE, IN
Is this just a ground for the SN alternator? I've got a jump plug to a new edge alternator and only uses the green and white w/ yellow stripe.
Also wondering about this wire. From what I remember I think it's the ground from the stock fuel pressure regulator. I can't remember just want to be sure before I cut it and tape it up out of the way.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
The single wire for the alternator jumps the stator inside. The new edge alternator doesn't have that?
That single black wore grounds to the bolt for the fuel rail.
mustangmurley
mustangmurley
FORT WAYNE, IN
Does the alternator have a spot for a single wire on it? I wouldn't ground that white wire just yet.
I'll take a picture of the alt plug from the jump to the 00-04 alt tomorrow. I believe it's just the two coming from the alt tho the white w yellow and the green.
mustangmurley
mustangmurley
FORT WAYNE, IN
Working on a rear seat delete and possibly some new seats too. It's been awhile since I've spent some money on it lol
mustangmurley
mustangmurley
FORT WAYNE, IN
Finished up getting the new carpet in last night.
Test fitting the seats. The brackets I got are 1.5" too short for the rear bolts so I'm going to have to shim it up but other than that everything lines up well after busting the head off three of the bolts and drilling them out everything lines up. Currently I only have the driver side seat when I placed my order they were out of stock on the passenger side for 4-6 weeks.
Also finished up the rear seat delete template. I just need to cut the plywood and wrap it.
mustangmurley
mustangmurley
FORT WAYNE, IN
QUESTION:
About to finally pull the trigger on new rubber. But I have a few questions. 305 will they fit without rolled fenders and flipping quad shock? The 305 is about 80$ cheaper than the 285 which is the only reason I'm looking at them.
ElrodKTPQ_89
Crossett, AR
My 295's scraped the edges of the fenders, and i didn't have quads at the time so no idea on that. But if you have tubular LCA's you can trash the quad shocks. If you don't have any then you need some lol
BMAC96GT
Virginia
Always wondered this. All you need is tubular lowers and you can ditch the quads?
Alida81
