mustangmurley
What brand is the K member/a arms?
UPR
Subscribing, interested in K member install. what made you go with upr? Did you do a lot of research? I'm looking to switch out my K member also, I was looking at team z but am still in the early stages of research.
If you have the certificates and it's not alignment issue. They'll send you replacement.I did get them from discount I'll have to check with them to see if they still have my purchase on record.
Looks like your alignment may be slightly off
If the alignment was off wouldn't it wear the passenger side also? Passenger side is fine. I'm thinking a belt in the tread just let loose or I ran over something. An alignment is in order after the k member is installed anyways but it's got me stumped.
That's what I have heard also some fit perfectly with zero problems and some are a little difficult to fit in. I decided to go with UPR because I got the k member a arms and coil over kit for $650. I had looked at the maximum motor sports k member kit but it was much more expensive and for what I'm using my car for I don't need the maximum motor sports I should hold my breath because now I'll prolly have a world of trouble installing the UPR k member. I also found out some information from nicks 98 slow build thread he just installed a UPR k member on his stang.
So you had the certificate?Ordered the bump steer kit this morning. Should have the new tire and k member kit in by the end of this week. New k member should be in by the end of January!
sent while thinking of mods for my 4.6s using tapatalk
You wouldn't necessarily wear out both tires. It's possible only one would wear out from a bad alignment
