My Cam update!!
Rantheman
Well I am getting to the point were I am ready to degree my cams I just havn't figured out which route I am going to take if I am off from the specs. one is I will grind the keyway off or 2 I will use the chain to bring it back not sure yet. but this Project has waited to long I need to get done I have been really busy as you can see i have some surface rust on my cams now but I oil them every other day. so bare with my and I will let you know how it goes.
The Motor
My plate For the dial indicator for the valve spring
Also made a plate for the dial indicator to sit for TDC(top dead center)
The motor again
The degree wheel the water pump is coming off tonight
R
Rantheman
opps i didn't mean to post this in the 5.0 section sorry :santa_embarassed:
Good luck man, that should be nice.
Are you going to dyno it afterwords or someting like that?
R
Rantheman
Matt-Thank you very much :santa_cool:
Droptop I did get your e-mail thank you
Dalmar- I am getting on the dyno after this about january
Alida81
