my update!!!
Rantheman
well tonight I got my injectors installed them man the old ones are in crappy shape anyways i adjusted the fuel pressure regulator and it started right up so I installed everything right fuel pump and all she runs better but need a tune bad. So I am going to set up an appointment for my dyno tune I hopung to pump out 300rwhp :banana: :bunny3: :dancing6: :bunny3: :banana: :drunk: :pimp: :behind: :naughty:
R
Rantheman
oh and here are a few pics
new injectors
old injectors
fuel pressure gauge
maf meter
fuel pump change
Looks good Ranth,
I gotta drop my tank next week to put in an inline.
The dyno tune will be sweet.
Let us know how it turns out for ya!
R
Rantheman
she pinging a little looks like I need to bump the psi a little on my regulator
Did you adjust your tune to work with the 30lb injectors? If not i wouldn't drive the car until you do...its not like the 5.0's where you can trick the MAF to work with different injectors, they must be tuned to work together or you are asking for trouble. It will run good or so you think but the injectors won't be pulsing properly.
R
Rantheman
Well I got a maf thats calibrated for 30lb injectors but my computer still thinks there 19lb injectors so you are probably right I will be getting a tune in about a month but right now until then she is sleeping in the garage after a nice bath with a warm blanket on :dancing6:
STNG_96
I thnk you will be able to hit 300 with that setup
bs.austin.tx
