Name this part!
Flade
Niceville, FL
Just finished swapping a pair of Windsor Heads onto my wife’s 98GT.
Had this washer and bolt left over.
I’m thinking it looks like one used for the oem style cam chain guides. But I swapped those out for an aftermarket style a few years back. Anyone recognize it and have an idea where it goes?
F
Flade
Niceville, FL
Yep, timing chain guide and insert.
Thanks for confirming it. Weird though. I didn’t remove the guides , just then tensioners. I replaced all of that a couple years ago and they were still in great condition. You can see that this style doesn’t use that washer. I must have had it lying around.
96blak54
Lawrenceburg Kentucky
Hold up!
Wait!
You need to swap out them plastic tensioners for cast iron ones. Its not a matter IF they fail, its a matter of WHEN they fail because they will fail....aaaand thatll be the end of your engine.
F
Flade
Niceville, FL
Ok, I think I figured out what happened. I saw kits on summit with both style guides. According to the kit, it contains:
2 Guide Rails (plastic - Windsor engines only)
2 Guide Rails (half metal and plastic - Romeo engines only)
So the extra washer is for a Windsor engine. Not my Romeo. It must have been with the other hardware I got with the Windsor heads. I think I can call this one solved and don’t need to pull the timing cover!
96blak54
These circled are plastic chain tensioners and you NEED to swap these POS out for cast iron. The plastic tensioners will fail! And so will your engine. The plastic chain guides are ok, but you will fare better with steel or aluminum backed versions. Hope this clears up the confusion
F
Flade
Niceville, FL
Thanks. Already done at the recommendation of others here! That pic was as I was tearing it down for the head swap.
96blak54
Excellent!
I thought to myself, what kind of person am I to not stress about them plastic tensioners! So I stressed! Im glad you swapped them out and sorry to sound like a pain
F
Flade
Niceville, FL
Excellent!
Not at all! I am very happy to learn from everyone else and avoid easy mistake…I make enough of them ones already! I have a long history with SBF engines, but the Modular’s are still new to me.
happliye
