Phatboy
- Joined
- May 27, 2013
- Messages
- 111
- Reaction score
- 0
Howdy. So I got my engine back from the ex today Woot! I have a few questions. This is replacing the stock 5.0 in my 95 GT.
Its a fully built 331 stroker from Coast High Performance.
It is based on the fox 5.0 block.
1. It has a trickflow upper intake with a 70mm BBK Throttle body. Should I switch to this setup or stay with the SN style TB? Ok, staying with the fox style, upgrading to a 90mm because I was told the 70 might limit my top end power? True?
2. It has a fox style distributor with the TFI on the dist. Can I swap this and use my SN style TFI and distributor? Staying with the SN style. Thanks
3. Since its just a bored and stroked 302 shouldnt all my accessories fit right back on the 331? Got my answer here, thanks. Use my timing cover adn water pump!
4. Will 30# injectors be enough or should I go with a larger injector? Engine mods listed below...Gonna wait till its in and getting tuned to decide on this. 30s will get her started.
5. Is an electric water pump a good idea, or just go with my stock and swap it over? Stock
6. Will a canton 7qt oil pan work on the SN, and if NO, can I use my stocker? Can anyone answer this one for me?
7. Will I need aftermarket fuel rails or can I use the stock ones from my car? Same as injectors, gonna wait till tuning time.
8. Will I need an AFPR? See pics below?
ENGINE SPECS:
Dished probe SRS forged pistons
Probe 4340 forged Hbeam rods
Scat 4340 forged crank
Main girdle, and windage tray
Canton 7qt oil pan
Ford racing SFI balancer
Billet flywheel
Edelbrock Performer heads 2.02/1.60 valves
Trick flow stage 2 cam
Trick flow track heat upper/lower intake with phenolic spacer
70mm BBK Fox style throttle body
Melling high volume oil pump
Scorpion 1.6 rockers
All ARP hardware
30lb Ford Racing injectors
ENGINE SPECS:
Canton 7qt oil pan
Billet flywheel
All ARP hardware
