Need a convertible top guru - adjustment
Todd in KS
SE Kansas
I hope there is someone out there who can help or point me to someone that might be able to help. My '99 has had an issue on the passenger side with the window catching the edge of the top when closing the door, now with the colder weather, it is happening on the drivers side too. I bought the reprint top maintenance manual but it has very limited information on trouble shooting and adjusting. I tried adjusting the cam wheel at bow #3 with limited success, . I am willing to pull the back seat and trim panels but don't want to if I don't have to. Thanks for any help.
sounds like it is either going up a little too far or is off track for one reason or another. There is an adjustable stop and while your in there you can take a look to see if all the plastic pieces are still in the tracks.
Fawls
Auckland NZ
As above it looks like your window going too high, there are adjustments but it is more likely that the rail that hits the stop has detached from the glass so the glass goes too high.
If that is the problem it is fixable, there are YouTube vids on it and late model restorations sell a bar to support the repair. I made my own, so far so good.
Mustang5L5
Take a look at the front of the window where the side mirror is. Does it look like the window has gone up too far?
I just go through repairing this on my convertible. The front window guide at the bottom became detached. I used the LMR kit to repair this
Strong indication this is the issue is to roll the window all the way up and look at the side mirror and the angle at which the glass joins it. If the window is 1/4” or more higher, this is your issue.
Testguy
