https://www.diablosport.com/spages/supportdocs/Copy_Original_Backup_Last_Tune.pdf
That should help you out a lot.
It could have been that the cats were clogged up. You can you tube how to load tunes to a diablosport predator and some videos come up. You will need a program called DSDownloader. I will try to find a link. With your cable, when you plug it in to the computer at the bottom does it say that the cable is ready to use? Also, do you have a power source for your predator?
Also my cam specs:
Crower Stage 2 Hot Street Profile
[email protected] Lift: 208/212 RR 1.8/1.8 Gross Lift .559/.570 LSA 114 RPM Range 1250-6000 Redline 6500
Comments? Ive read a few threads where people also called these sleeper cams, or very mild for stage 2
Are you trying to boost the car or do you want to stay n/a?
I'll just do N/A
Ok then go with the 38cc head and get that compression up. There is a guy here, 03DSGGT , that has a similar setup with those heads. He makes great power and his car is quick. He might be able to help out a little bit.
Trick flow heads need trick flow head specific cams. The exhaust valve being reversed puts the exhaust lobe timing events out of spec when normal inline valve cams are used. We're talking 50rwhp! This is why some are only extracting 350rwhp when it should be 400rwhp. Their is a popular hotrod issue with the swap, check into it.
