Need help plz !
94Stang
I have a 94 5.0 Mustang. Last night i went to change my PCV valve and the plastic T broke. I shut the project down for the rest of the night but needed to move my car cause of bad weather. Anyway i cranked it forgetting that the lines were unhooked. The car barely crank and sounded like crap. It then died on me. Fixed the lines and PCV. Car won't crank now and having a really hard time trying to turn over even. Car ran fine before all this. What could it be ?
blackdemon007
Ohio
Double check all your lines.
Make sure they are run correctly - may have gotten a couple of them backwards.
Also look for any other lines (vacuum or electrical) that may have come unhooked during the project.
94Stang
94Stang
Thank you i have it all pulled down but at work today so won't get back on it until tomorrow
99GreenStang
PCV wouldn't cause car too not run . You have disconnected a vacuum line it sounds like on accident possibly . Good luck
If it won't crank, I'd start with your battery.
94Stang
94Stang
Battery is brand new. Turns over but having a really hard time. Like its not firing correctly
Did you do anything with plug wires? Or distributor? Almost sounds timing related.
94Stang
94Stang
I was thinking the same thing. Just made it home fixing to tear down into. Ill let ya'll know what fine. I installed a MSD cap rotor and wire awhile back.
Well, make sure you used the HO firing order when you installed the wires.
45538d1212118912-firing-order-302-e303-cam-43815d1209725593-1994-mustang-gt-5-0-timing.gif
99GreenStang
Hard cranking sounds like distributor is too retarded , advance it a little and see if it cranks over for you .
94Stang
94Stang
Well i learned the distributor housing was cracked. Not sure if this is all of the problem but gonna start there. But got to put a new engine in my truck so gonna be away from the stang for a few days
99GreenStang
Well the distributor housing being cracked would cause the car to be hard to start but not hard to crank unless your dizzy is stuck completely or something . My bet is dizzy .
TreeScholar
