Need help with AC
Downshift
Ok, so its been about 105ish lately up here around sacramento and my ac in my BLACK car with leather isnt working :rant:. Lets just say I feel like im in hell.... Anyway Found the problem to be my A/C compressor. The AC was blowing cold air fine about a month ago. The clutch seems to not be engaging on it. So I have a few ?s
1. Has anyone been able to fix this, or know a possible cause for this so I can try to fix it myself?
2. Can I use a fox 5.0 compressor if I dont end up having to buy one? Or does it need to be a 94/95.
I need some help guys im burning up :hammer:
Tattoogod
the compressor will not engage if the gas is low..have you tried to put more r134a in it?
Downshift
Cant afford to move nor do I want to lol. I havnt tried putting more in, I will buy a gauge and see if it is low.
Tattoogod
also check the fuses and relays.the compressor's not always to blame..worth a try.
Downshift
Are there any more fuses or relays I should check besides the fuse box or is that it?
HISSIN50
I would use manifold gauges. You really need to see high side pressure too (let alone that those dippy low-side gauges are kinda inaccurate).
With good gauge data, you can get it figured out.
Good luck.
94yellowgt
I would check the low pressure switch on the firewall. Unplug it and use a jumper wire to see if the compressor kicks on. If it does kick on and you a full of freon, just replace the low pressure switch :thumb:. I think that is a very common problem with the A/C on our cars.
wytstang
Beat me too it the pressure switch as called the cycling switch that sits on the evaporator (black canister near the firewall) useally gives the same symptoms.
Downshift
By jumper wire do you mean just a piece of wire to skip over something? Sorry I feel retarded haha. Im still kinda unclear on what to do. Thanks for the help though.
94yellowgt
Yes, just a wire. Start the car with the A/C on and unplug the pressure switch on the firewall and put one end of the wire in one terminal and the other end in the other terminal and if it kicks on, that your problem.
Downshift
Well I tested it today. Came right on, but wasnt cold so I put some more R134 in there. My friend tested his turned out his switch was bad and he was low but Just need to get a new belt tomorrow and I will be having AC!!! So Im really happy.
94yellowgt
I'm glad that we could help. Hope you get it working soon.
Downshift
Yeah I will have the new belt tomorrow, thanks again for the help I almost gave up lol.
Methodical
Do what he says and if it gets cold you don't need any freon just a new switch
NastyStang
what if your compressor does not cut off?
if it just keeps running
It blows cold but will not cycle off
Nastystang??????????
