Knightstallion
- Joined
- Jun 19, 2021
- Messages
- 103
- Reaction score
- 15
Nothing was broken from the distributor, but I can pull it back out real quick and take a picture, what I'm talking about is the angled section on the right hand side, zoom into the photo you should be able to see it, that's not a shadowGuve me a picture of the bottom end of distributor to
Oh thank god! Ok so there no play that I can tell on the distributor shaft, but the pin in it does look like one side is uneven, don't know if the pictures I just put up are good enoughYou are good to go i had to double check with my block View attachment 10914
I am the second owner I got the car in 09 I think. I found an envelope behind the dash when (well they found) I had to take it to have the vacuum lines on the vent controls replaced, it had a recall sheet (something about the hood) from 96, I actually got in touch with the lady and found out that she had just sold it to a car dealership a few months earlier, also when I told her I had named the car Ruby she laughed and said that was what her and her son had named itYa I see it now it dose look broke on the corner
Should be round and flat on part of it
Metal parts should be in the pan that could have happened at any time are you the original owner
And as long as the distributor sits on it flush and has no movement side to side back and forth you should be ok to use
Thank you for taking the time to get that picture. I couldn't find verification anywhere that it was or wasn't broken, now I can get back to my original witch hunt on herYou are good to go i had to double check with my block View attachment 10914
Ok it's got a little movement up and down , but not any wobble on the rotation I'm going to take some pictures with calipersYa I see it now it dose look broke on the corner
I'm glad you did, and glad you happened to see my postNo problem
Its been a while I seen that part of a 302
Had me questionon on that one
I have a spare block just sitting
That was a good sample
Those are all very good things I should consider, I'm on my way to the parts store to see if I can get a tdc tool and some wiring for the trucks fog lights (think I might have figured out how to not burn down my truck, but according to a diagram of the distributor and firing order my distributor looks like it's twisted about 20 degrees from where it should be, but my rotors is on the plug going to 1 and my timing mark is on tdc or 10 past whichever the thing is actually marked for. But I gotta verifyHow many miles on the car
The chain may be stretched
The ford dealer recommends every 60 thousand
Replace chain and gears
That was way then
And also cam gears were plastic back then
So how would I determine if it was stretched, or should I just replace it and be done with thatHow many miles on the car
That was way then
