Need suggestions
94BlkSnake
I've had a 94 Cobra for about three months. Never had a problem with it so I park it in the garage last night and when I go to work today every time I hit a good sized bump it sounds like the rear axle is trying to come through the back seat. I jack the car up when I get home and I can't see anything wrong.
The car has an Eibach Pro Kit that was installed by the previous owner. Any ideas? Shocks?
d_punch
check your rear sway bar. when mine broke i would hear a pop, or clank when i would do tight turns, or go over bumps.
it has 2 bolts on each side, and mine broke in between the bolts. best way to find out is to just push up or down on it and if it's broken it should make noise. if you need to use your feet to push on it.
or it could be you spring isolator?
good luck
Joe
d_punch
94BlkSnake said:
Thanks d_punch :thumb:and everyone else. It's the sway bar.
i need your shipping information, so i can send you a bill. :hammer:
qzxo_oxzp
