heffe2001
Mustang Monthly had a write up on how to swap out the bezel for the 01+ cars in the older models (it's how I did mine, still need to adjust the radio back a hair to get the radio bezel to mount flush like it's supposed to, and you have to cut a piece of your dash out for the buttons):
http://www.mustangmonthly.com/techarticles/mump_1304_1994_2004_ford_mustang_interior_upgrades/
You also just can't wire up the defrost switch and it work, it requires the relay in the existing switch to be present. Without the existing switch it won't work. Write up over on SVT Performance from TheSinner on how to do that:
http://www.svtperformance.com/forum...in-conversion-picture-heavy.html#post13443915
I still need to get the real harnesses for my buttons, so I can splice in for the traction control and fogs (probably will replace the one on the defrost as well, it's not the most secure method that I used, lol). If you mod the existing defrost housing like I did (same with the wiring), it will fit behind a later model dash insert without the defrost hole fine. You still hear the click from that module when you hit the button on the lower panel, but the LED lights like it should and everything works perfectly. I'd definitely suggest you either purchase or otherwise aquire the real button harnesses, it'll make your live MUUUUCH easier, lol. The traction control and defrost switches wiring were the same color code as my 2000, but I haven't had time to cut/splice it in yet...
