New 98 gt project
Randall Garner
US NAVY
Just brought home a 98 convertible. The trans seems ok. But the engine has a bad miss. Going to get tune up and go from there. Not much experience with the mod motors. What other issues should I look at . It's been sitting since. 2013. The fuel pump was changed. To get it running. Looking to get it in good shape to eventually give to grandchild as first car.
96blak54
In the shop
Plug wires is a good start. Make a round of reseating the plug wires to ensure good connections. I find alot of times the plug boots push the connections off the sparkplugs and coilpack post terminals. While youre at it, be 100% sure that no moisture/water is down in the sparkplug hole....them holes have to be dry.
Then replacing plugs and plug wires would be my next step.
Randall Garner
Randall Garner
US NAVY
I have yet to do that, the guy I bought it for m did the pump. I haven't gotten it up on the lift to see if filter replaCed. Added to the to do list
Randall Garner
Randall Garner
US NAVY
Thank added to the. To do
Randall Garner
Randall Garner
US NAVY
Thanks. I'm going to replace sensors and coils while I'm going through it. Just to ensure ecm is getting the correct signals
weendoggy
Before you throw $$$ at it, do a compression and leak down test. That way you'll know how good/bad the engine is. If all good, spend $$$. ;)
Randall Garner
Randall Garner
US NAVY
Thanks one last thing for everyone to chew on,. I did a poor mans injector test , pulling the signal wires, one at a time ,. Found one dead. Checked wiring with a test light and wiring appears ok. So if no change to engine. Could it be a bad injector. Already changed plugs and wires. Still going through the mess that's the wiring harness. Thanks in advance.
96blak54
In the shop
Yes injectors do crap out. If its a stock injector you are in luck, cause a plethora of them are available on the cheap. Any bone yard with a 4.6l ford will most likely have what you need and wont cost much. Just be sure to match it. Make sure color, the size, and harness connections are the same. Ford began changing the injector types around 98.
weendoggy
Actually, you should be using a noid light to test injector harness, not a test light to see if it's firing. You can do damage to the electronics. Injectors can be a toss up on good/bad. Easy way, again before spending $$, is to exchange it with a "known" good one in your system. i.e. swap bad #4 with good #1, then if the problem followed the swap, spend $$. :) Of course, all things being equal would be to know if the engine is in good working order as I suggested in post #10.
Test lights are good for checking a lot of things in our cars but stay out of the ignition/injectors/airbags because as he said they can cause problems there
Randall Garner
Randall Garner
US NAVY
Thanks for all the advise. Did compression test. All within a couple # of each other. New coils, wires, plugs and injectors. Car runs nice. For something that sat for 8 years. Going to have to invest in new springs. It looks like a previous owner. Did the rose bud spring drop overly stiff and bouncy. I know eibach has a decent lowering spring set. Any other companies that are recommended
