New alt & PS pump
Daryl
Daryl
SoCal
Tests went ok.
Results:
1. Code 172- HEGO (HO2S) sensor fault/lean;
2. Code 136- HEGO (HO2S) sensor fault, always lean.
Now the next obvious question is: which O2 sensor? Or is there only 1 or 2?
The only funky thing that the Code Reader displayed was the # of cylinders. It displayed 4!! Last I checked there’s 8 cylinders under the hood!
Daryl
Daryl
SoCal
Ran the 3 tests. Got 136 & 172 Codes. Yep, O2 sensors (lean, always lean).
Buttoned everything up, started it up to see if Check Engine idiot light still on?
Nope. No more check engine light.
Drive it around a long block to see if it would come back on?
Nope. Still off!
So maybe it was throwing a ghost code??
Either way, I’m going to give it a “wersch” and go drive the sum bitch!! :)
joemomma
I believe there are only two 02 sensors, but I don't know how to tell which is which from the tests.
There should only be 2 test KEY ON ENGINE OFF
KEY ON ENGINE RUNNING
check make sure no oil is present at the wires on the sensor part
the wires going into the body of sensor.
Daryl
Daryl
SoCal
Yep, the Check Engine light came on/stayed on again during my drive to work this morning! Also, the turn indicator is on steadily and my headlights and fog lights aren’t functioning properly.
Daryl
Daryl
SoCal
Yep, came back on. Green indicator light on constantly now and fog lights don’t work.
Great…:-(
Daryl
Daryl
SoCal
Will do. Picking up 2 OE (NGK) sensors and slotted socket today. See if this helps remedy
Daryl
Daryl
SoCal
Came back on again, but not right away. I guess the sensors need time to send signals?? Whatever. No more indicator issues somehow but looks act up when headlights activated.
Going under the car now….
Daryl
Daryl
SoCal
Well, 2 new O2 sensors ahead of each cat. And check engine light is gonzo! Drove it about 20 miles since and another 40+ tomorrow. Hopefully I won’t get a check engine light!
wbarter
