Wells.Strength
Hey!
New here! It’s been quite a few years since I’ve been in a Mustang, back in the day I had a 97’ Cobra that was my baby! Back in 1999-2003 then like an idiot kid I sold it and soon left for the Army. Anyway…
New build now! I have a 95 GT that I have started a build on.
BOSS 347 short block
SVE 185 heads
Trickflow hydraulic lifters
1.6 Trickflow roller rocker arms
Manley swedged pushrods
ARP head studs, ARP fasteners throughout…
Hot forged high performance distributor
MSD Plugs and wires
Protourque starter
Power master alternator
Canton Oil pan 15-640
TCI Forged flexplate
High volume oil pump
High volume water pump
Comp cams dual roller timing set
Trick flow track max stage 2 cam
Trick flow track heat intake (with 1” spacer)
BBK 75 mm throttle body
Custom MAF 75mm and 47lb injectors
47lb injectors
255L/hr Fuel pump
SR performance cold air intake
SVE Aluminum radiator
BBK equal length shorty headers
TCI street fighter torque converter
3:73 rear end gears.
Mega squirt plug and play set up
That’s basically all of it… I think..
Looking for any pointers anyone may have.
Especially for fuel rail adaptations with the Trickflow intake and larger distributor.
EGR deletion…
Want to delete basically everything I don’t need. Just going to keep the AC for now… probably not for long. SMOG is gone as well.
SVE 185 heads
MSD Plugs and wires
Protourque starter
47lb injectors
255L/hr Fuel pump
EGR deletion…
