That shop sounds like the one that
ReplicaR had a bad experience with. maybe he can chime in
F*CK Wild Pony Motorsports. Expensive shop, the guy is a shitty tuner, terrible engine builder, and you get charged fore everything, including for his own mistakes. If I were you, I would never set foot in there... EVER. They've been working on my car for years, doing small stuff, mostly shit I was too lazy to do. Then I've used them to build my first motor. The motor came out to be more expensive than originally planned, because the shop owner would waste time on doing stuff that he should have called me to consult with. The car spent 4 hours on the dyno, and could not even make one wide open pass, not to mention that it was about 50 rwhp down on power by comparison to a tune done by another shop. The motor leaked oil from both sides, broke rocker stud, blew header gasket, and cam retainer plate backed off (no locktite on bolts), causing the cam to grid off its distributor gear and send a bunch of metal through the engine. Oh, and did I mention that the torque on everything was all over the place? I know for a fact that the engine was assembled by the apprentice, who was pretty much working there for minimum wage. After taking the the car back multiple times, I complete gave up with that shop, and took it somewhere else to get it straightened out. And just for fun, the oil cooler line that he made during the engine build blew off during a dyno session at a different shop
Saul Gutierrez of Gear Driven Automotive (Extreme Automotive at the time) sorted my car out. The engine was pulled and completely redone, minus the piston rings and bore, because that was still good. They added main cap girdle, painted all of the accessory brackets, new main bearings, new oil pump, torqued everything down, replaced some bolts with studs, replaced the camshaft, and tuned the car as well, so not only did it make a wide open pass, but it also drove well, and made 360 rwhp instead of pathetic 308 rwhp. I would highly recommend Saul. He is flexible to work with clients, he stands by his work, and he does quality job. I can't really think of anything that required for me to go back to him, and ask him to fix it again.
