JR Jones
Came across the forum while doing research. I picked up a 1997 Mustang GT Convertible, harvest orange with a little over 140K on the odometer. The last Ford engines I worked on was the older 5.0 and 5.8's. I'm mostly a Chevy guy so hopefully I can be schooled on the modular engines. Will post pics when I get around to it.
JR
J
JR Jones
Your dues are doubled then but I take check and it doesn't even have to be one of your own.
Ha ha. Well Most of the fords I’ve owned were trucks. In Europe I owned a 1983 Capri and a 1992 Escort RS Cosworth. I’m digging this car but I’d like to build her a new engine.
Shaggy
Administrator
Admin
Arizona
JR
Welcome to the forum. Post up pics of your vert.
Burninriverdiver
Welcome to the site, there's a lot of mod motor guys on here that can teach you a lot. They're not that bad to work on but it helps if you know some of the shortcuts for working on them
RAU03MACH
NEW MEXICO
Welcome to the forums looking forward to checking out your ride
so post up the pics .
J
JR Jones
OK. I need some better pics but there is time for it. So , 1997 GT, 5-speed, Autumn Orange. Nothing major done yet. Flowmaster exhaust (Cat-Back), BBK Cold-Air Intake, Aftermarket 17's. I've had the car since April of this year. This weekend I'm installing new rotors and a brake job. I have some Eibach Pro springs and shocks on their way as well.
I'm looking at building a new engine, something mild in the 350 to 375hp range. I'd be happy with 350. I'll gladly take any suggestions although I'll probably stick with a decent short block kit and build it from there. Because I'm not looking for tons of power I can stay mostly stock on the bottom end. Thoughts?
When I build the engine I will then change out the X Pipe and go with headers, swap in a better built transmission, and a built rear-end.
RAU03MACH
NEW MEXICO
Nice stang like it
have you changed the gears on the differential yet 3.73 will get the car going
on the 4.6 sohc engines a lot of these guys have good ideas
I myself am experimenting with 4.6 dohc and a lot of knowledge on 5.0 engines
just ask, these guys will chime in to help you
J
JR Jones
I have not swapped gears yet. That will happen when I swap the rear-end out for something better. Do I need it? No. But if I decide to ever pump the engine up more I'd rather not do this twice.
The cosworth will give you a special pass for the hazing, but that isn't always a good thing.
Harvest orange rocks pics or ban...
evilcw311
Most Evil Member!
Louisville, KY
Harvest orange is one of my favorite colors on the sn’s. I wish they’d bring it back.
virocanah
