WOOHOO! just snapped some quick pics of the stang now that its lowered so you guys could check it out! They are the prokit springs with all isolaters installed and FRPP adjustible caster camber plates. tell me what you think!! thanks guys.
Hello, Great look, great color to O0 ! What is the change after you install caster camber plate ? I never understand what is the reason of this part. F.
It allows for the correct caster/camber of the wheel after lowering. When you lower a car, you mess up the geometry of the suspension. These plates make it so the geometry is correct. The tires would usually not sit perpendicular to the ground and cause uneven tread wear if c/c plates weren't used. O0
thanks for the feedback guys! well i have a slight exhaust leak at the manifold right now but its getting fixed on thursday so ill get some sound clips after that and post them up for you.
