New Seat Foam
bluex
The reason it only works with the TMI upholstery is because the factory upholstery is glued down to the foam. The TMI stuff is desigened to be hog ringed to the foam. I also think the shape of the TMI stuff is slightly different than the factory stuff. I havent got my front seats redone yet so I cant say. I've done the back seat so far and the worst part was getting the covers off, otherwise it wasnt to bad. The fronts should be easier since I'm not reusing the foam. I think with the foam and new covers I have about $620 in it. I was getting quotes of $500 local just to redo the front two seats with the factory foam. I think this was the better route to go personally.
Ballistic
Ballistic
Oregon
Dang that sucks, i may just save up for some Corbeau seats if i cant find any used seats i like..
Has anyone ever put in like 05+ seats in our type of cars?
white95
Apex Junky
Admin
Prairieville, LA
Standby for pictures
I don't know why but I've always liked the way the stitching looks in that picture..
Ballistic
Ballistic
Oregon
That looks *****in' would love to put the recaro ones in mine but i bet those would be too much..
Pretty easy to put in?
or did you buy a new base and mod it to work?
I just got corbeaus
white95 has s197 seats
What ones did you go for? And any pics?
white95
Apex Junky
Admin
Prairieville, LA
Removed the s197 tracks, drilled a few holes and mounted the sn95 tracks directly to the seats.. Fit like a glove!
white95
Apex Junky
Admin
Prairieville, LA
power part works i take it? What about heated seats?
Picky, picky!!! Lol, I went manual tracks to save weight. However, you can use the S197 stuff if you're proficient with a welding machine and create a way to adapt to the sn95 bolt pattern. As for the heater, what year s197 has heated seats? Our '05 doesn't but you would only need a power source and a ground.
Look up Mika and view his build thread for the adaptors...
Ballistic
Ballistic
Oregon
After seeing the Corbeau TRS wide seats - http://corbeau.com/reclining-seats/trs.html
Thinking i want those now need to find a place to try one out and i shall start saving for those after my damn wheels get instock..
Grand Total $1,181.38 shipped w/ seat heater on driver side
Edit: Note: Wide seats will only fit 79-93 Mustangs if no console is used. Will not fit with factory console
Dang guess that saves me 100 bucks
Tom76
