new upper intake installed
identity_Crisis
a few pictures of the progress over this season
the last 3 pictures are the new intake
and the new grille for the front
Goindeafonmtx
So you went from single port to a 99+ Mustang split port. Then you swapped it out for a Windstar upper right? What year is that off of?
I
identity_Crisis
the intake is from a 96-98 ford windstar
and well not sure ont he HP gains but the car went from 11psi -18 psi with this intake
97vertstang
what did u need to modify to install it??? and i wonder why ford never install it on the 3.8 mustangs???
blown95sixer
From my knowledge those intakes flow extremly well!!! If you had nitrous you would see very good gains over the stock split port intake. Nice work on the install. How hard was the splitport swap?
I
identity_Crisis
the split port swap was much easier then everyone leads on
there were no real problems with it a few very small things but what can you expect
it was about as hard as the procharger install and that was straight forward
blown95sixer
How did you have it tuned? Did you use your same wiring harness. I know you have to modify the fuel rail, but after that what complications do you run into?
Spyder
looks good man
where did you get the tubing for your intake?
I
identity_Crisis
all the piping was made by me at work i work at an international truck dealership and i got all that in the parts depo and all my T clamps not in those pictures btw
TreeScholar
