New wheels & tires advice
ko 5.0
Hey guys, I am going to order new stuff on Wednesday. Here is what I am thinking
American Racing Razors, 18x9, 275/35/18 all around with rims being 24mm off set, 6" backspacing.
I want the wheels out towards the fenders. Will I need a spacer or will they look ok fine with out?
Lightning Struck
those should look pretty good, and yea you dont see them often. Post pics when you get them on
Dalamar
SLC, UT
cool, those should look different.
you'll definately want to space them right out, especially in the back
K
ko 5.0
If anyone wants to reply to this that would be great.
Do you think I will have a problem with 18 x 9 with 275/35/18 when I install the Eibach Pro Kit springs?
What about offset?
Julian Moore
I run an 18x10 with 295.35.18 drag radials. They fit great but to go flush with the fenders I put a small spacer..maybe half inch. I run 265 up front...275 may be too big..stick out a little. I have no pics..lol..I can take some this weekend if you like.
Dalamar
SLC, UT
I like the second wheel better.
The offset - what offset's are avaliable with those wheels?
lowering wont give you any clearance issues, especially with only 9" wide.
If the offset is the same as the front, you'll need spacers for the back.
If that's the case, mount them, and measure it out - to be sure.
K
ko 5.0
The 18 x 9 has 25mm offset and 6" backspacing. Should I consider a different tire size?
Larimist
