Bought a ZEX kit and had a couple of questions. I have to wire into the TPS, as far as I can tell, it is the top wire on the sensor, the gray/white wire, correct? Also, where should I wire the power for the switch inside the car? Says I need a 12V accessory. Was thinking going right to the fuse box... Thanks
+1 dont be one of those guys who just pulls a fuse out, sticks a wire in and then pushes the fuse back in
Haven't even gotten around to messing with it. Work is running me ragged... I needed the wire to sense WOT for the nitrous to activate. Figured it out that it is the one in the center.. Thanks
