Nitrous on our cars?
smokinya9
you can run up to a 75 shot without a tune 100 to 150 can be run safely with the proper tune
Dalamar
SLC, UT
Ive read up to 125 shot, WITH tune.
I think over 90 shot and you need an inline fuel pump to keep the pressure up.
My nitrous is a 150 shot, and I'm adding the T-rex inline pump.
95CALI-5.0
congrates on the 300 posts.
Regarding the shot of NOS. Your motor can handle the shot, just make sure to get a CORRECT tune for your car. Doesn't matter if you have a DART block and all the forged internals you can buy. If you have a $hitty tune, your motor will go bye-bye!!!
Don't skimp on the tune
96mod289
from waht i understand it can be done ,but i would upgrade your fuel pump at least anyways.
1996mustangGT
jsut check with the dealer you get the nitrous from,
theyll probally be able to tell you what to do
smokinya9
you can run a 150 shot on stock fuel system with the proper TUNE but it is a good idea to uograde your fuel system start with a fuel pressure regulator then fuel pump your stock 19lbs injectors can handle a 150 shot but they will be getting a workout when you spraying if you have boltons the next thing after that I would move up to 24lbs injectors and make sure to have fun with the JUICE lol
Scott 96Cobra(rip)
Lets see if I can help ......
Safely???? What does that mean?
With a proper tune (As mentioned) on a perfect day with perfect conditions ..... SURE!!!! 100%
Now here come the "But".
BUT .......
What if your bottle pressure just happens to be sitting at 1100 instead of the 950 you had it tuned at? More bottle pressure = more air = lean.
OR
Perhaps bad air (good air = bad air - because you will gain HP)
Or, lets say the pump fails for a second ...... or your fuel tank is a little low ..... or you detonate because of bad gas ....
The point I am making is that if ANY of these happen on a 150 shot with stock internals you are going to think it's the 4th of July.
a 75 shot on the other hand is MUCH more forgiving ........
NOW That being said..... with a proper tune and a REALLY good set up (proper pump/pumps/injectors/warmer/window switch/fuel pressure cut off/WOT switch/ and any other bells and whistles I forgot to mention), you are likely to be OK, I just don't want you to think it's "no problem" and then have you blow it up without being told the whole story.
Just do it right :)
1996mustangGT
do the fuel system at the same time.
spend a little more now instead of
having to rebuild (or buy a new) engine.
97gtconv.
get a tune for however nitrous your going to run. get a wet kit, not a dry kit. normal goodies like bottle warmer, window switch....and run a 75-100. After 100 it will melt the pistons. I know on my 97's pistons the rings aren't really protected and are pretty close to the top so they get torn up easily.
caseypayne69
I've always read that a car that you want to be a daily driver, with its tune should never go over 20 hp per cyclinder. 8 Cyclinders = 160 hp. Then again it's hope that each cyclinder gets the correct amount of nitrious, but again thats why they developed direct port.
1996mustangGT
try not to get greedy....
cant you get a lower jetting than 75?
i thought that they made just a 50HP shot of the juice?
DropTopPony
South Jersey
scarface said:
I wonder if I could get away with a 75 shot on my car running 12 psi?
i'll be running a 75-100 shot on mine with 9psi but it will be on a built block with a seperate tune for the juice.
RobertC
