Michael Soldan
it stumped me for a while. I went to the fuse panel(1995 convert 3.8) and my test light lit up on both sides of the fuse , so what the heck. Then I wondered if I could have the worst coincidental luck in that both tail lights had burned out. Nope. I went through the fuse panels and checked them in the owners manual. After trying the normal trouble shooting I tried pulling the headlight switch off and on , the clock flashed and the cluster lit up, checked and tail lights on. So it appears to be in the headlight switch . I sprayed the switch rod with silicon, figuring that would lube anything during the off/on operation. With the headlight switch pulled out , I just have to move it inward ever so slightly and everything lights up. Does this sound like the switch is goin south or is it just signs of wear. Opinions welcomed.
