O2 sensor identification
HawkX66
Michigan and Mass
Before I start throwing parts at my son's GT, I'm trying to diagnose an issue. When I put the LT headers and new mid-pipe on, I wasn't paying attention to what O2 sensor went where. If I'm looking at all four of them on the work bench, is there a way to tell them apart? Bank 1 front, Bank 1 rear etc.
Pretty much since I rebuilt the motor there's been a stumble/light backfire in the higher RPMs when I get on it. When it's idling it runs at 800 rpms nice and smooth, then will drop down to 500 and quickly go back up to 800. It will do this consistently every 1-2 minutes. I cleaned out the IAC and dropped a little oil on the shaft, but nothing changed. It finally threw a dtc. P0420. Could this be because I put the O2 sensors in the wrong spots?
It has MIL eliminators and O2 harness extensions for the LT headers and X pipe. The only other "mod" is the K&N filter kit.
96blak54
Staff member
Lawrenceburg Kentucky
Connectors should be slightly different. Color of plug should be matching to location plug too.
Sent from my SM-G900P using Tapatalk
HawkX66
HawkX66
Michigan and Mass
Thanks. I was doing some reading last night and it looks like the only actual difference is the length of the pigtails. I guess the actual sensors are the same. So maybe one of them is bad. I went ahead and ordered new ones. Hopefully that will straighten it out.
I thought this was pretty linteresting too. It explains MIL eliminators pretty clearly. The last part was most interesting to me.
"MIL (Malfunction Indication Light) eliminators are used when an off-road mid-pipe (no catalytic converters) is installed. Your car’s computer is programmed to work with cats on the car. When you remove them, the check engine light will come on because of the readings that the car’s computer is receiving from the rear oxygen sensors. The MIL’s essentially trick the car’s computer into thinking that the cats are on the car and that the oxygen sensors are performing properly. MIL eliminators will not bypass a malfunctioning oxygen sensor. They will only shut off the "check engine" light when installed on properly functioning O2 sensors."
evilcw311
Most Evil Member!
Louisville, KY
I could of swore my buddy had to get a tune with his longtubes cause of a similar issue.
But I've been laying around the pool drinking all day and I don't do mod cars so I could be totally wasting your time by even typing this.
But in all my sunburnt drunkiness I swear I have your best intentions at thought!! Lol
Thomas_W
Capon Bridge, WV
It shouldnt need a tune a tune with just a LT header install, id say the O2's are probly at fault
HawkX66
HawkX66
Michigan and Mass
Rockauto usually has good deals and parts.
Thanks guys. I'm just not getting the warm and fuzzy that it's a tune issue. Even though I'm not getting a CEL since yesterday, I ordered 4 new O2 sensors off Amazon. Two are Bosch 15718 and two are Bosch 15717. I was able to get one of each for $22.10 and then 15718 $26.65 and 15717 $30.78. At least with Amazon prime it's free shipping and an easy return if it doesn't end up being the problem.
Other than that the car is running and driving great. I stole it from my son for a few hours yesterday... Hey, I filled the tank and got him a car wash. I'm not that evil lol
HawkX66
HawkX66
Michigan and Mass
Well, that's a bummer. Four new O2 sensors and it's still the same. I'm going to leave them in. The other ones were OE. I ordered some new off brand COPs last night from Amazon for ~$50.00. We'll see if they make a difference.
One thing I did catch while changing the O2 sensors was why the CEL came on. Some dummy (me) plugged two MIL eliminators in line on one O2 sensor. The other side didn't have an eliminator so it must have been what was throwing the code when it did.
My son and I stopped by Livernois Motorsports in Dearborn with it yesterday. Top notch business, but it'll cost you. ~$1,100 for a tune including the SCT handheld. Out of my price league. My son and I got a tour of the place. This is the type of place you see on TV with the temperature controlled clean rooms to build the engines. They won't touch imports so no fart can cars.
So we're still at... Take off normal and everything is fine. Step on it and she starts to break up and back fires a little like the timing is off.
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Man, I would really suggest staying away from those off brand coil packs. I put some in my car and the first time I turned the key, 3 of them let the smoke out.
07GtS197
Fort Myers, Fl
Your best bet is to datalog. You dont need a tune for longtubes per se but you can throw a slow response code for the front o2's. Also mil eliminators are notorious for not working correctly and throwing codes. My 02 will throw codes for cat below threshold sometimes too.
HawkX66
HawkX66
Michigan and Mass
I hear you, but at $20-$40/cop or so for good ones, I just can't swing it. The ones I ordered seemed to have pretty good reviews. I'm going to throw them in and see what happens. Even if they give up the ghost, I bought them through Prime so I can just send them back easily. This might at least tell me if it's the COPs or not. I wouldn't mind dropping $200 if I knew for sure they were the problem.[
The codes are sorted out. I just had the MIL eliminators hooked up wrong. Dumb, end of the night, tired mistake I'm sure. I don't think I need a tune. I'm sure this is something simple. The trick is to find it...
Is there a cheap way to data log via the OBD port? I have a BT OBD2 port hook up that I use with the free TorqeLite app. I don't mind buying an inexpensive program if I need to. Honestly I haven't looked that much into it. I have a program on my laptop for my 69 Camaro that I use with an AFR gauge to data log.
07GtS197
Fort Myers, Fl
Oh ok, just food for thought. Im not familiar with torque but I believe it does have datalogging capabilities. I use and am familar with forscan lite. I can help you figure it out if youd like.
As far as coils go, an engineer who used to be big in the mustang community, CliffyK, did a lot of testing with coils and found that most come from the same factory in china lol. I believe it was world products thats the oem manufacturer.
HawkX66
HawkX66
Michigan and Mass
I'll check out the forscan lite tonight. I'll let you know what I find. Thanks. My son will be out with the car so I'll have to wait until tomorrow to play with it. I had read the same thing about the COPs in a few places so I figured it can't hurt to give it a shot.
HawkX66
HawkX66
Michigan and Mass
HawkX66
HawkX66
Michigan and Mass
Thank God! Yahtzee! COPs for the win. We threw 8 new QYL coil packs on tonight and it's a new car. If you guys have had a bad experience with inexpensive COPs, give these a shot. They seem well made and according to the manufacturer's specs, they're made from the good stuff.
https://www.amazon.com/gp/aw/d/B01N10YNS5/ref=yo_ii_img?ie=UTF8&psc=1
As an Amazon Associate we earn from qualifying purchases.
evilcw311
Most Evil Member!
Louisville, KY
Glad to hear it worked out.
Now where's our smokey burnout victory video?!?! ;-)
nynce
