SlograbDC
- Joined
- Oct 19, 2024
- Messages
- 8
- Reaction score
- 5
Hello everyone, making this thread to see if anyone might know what problem I'm having with my new setup on my 302 with an MSPNP2 and trickflow upper/lower intake manifold - hopefully, if anyone faces a similar problem, this will help them out as well!
Recently had my upper and lower swapped out, as well as had my old quarterhorse tuned ECU replaced with something more modern, a Megasquirt MSPNP2. Driveability is significantly improved now, especially when starting, and acceleration is significantly better now too - I'm putting down about 250WHP at 4200RPM.
The complete build at this point has:
* AFR 185cc heads
* mildly ported upper Trickflow trackheat upper and lower intake manifold
* B303 cam
* 24lb fuel injectors
* BBK 255lph fuel pump and fuel regulator
* Ford Racing fuel rails
* 1.6 roller rockers
* Professional Products throttle body
* Fluidyne Radiator
* obligatory A/C delete
However, when I'm around 4800 to 5000RPM at wide open throttle, it breaks up and my tachometer begins reporting the RPM weirdly - I had it once or twice pin itself at 7000RPM when it did that, or increase by 500RPM way too quickly for it to actually be accurate.
I'm honestly not too sure what could have caused that behavior. Bad fuel filter, dying ignition coil, bad distributor maybe? Whats quite funny to me is that there was no timing pointer on the engine before tuning started, so I have *no* clue how the previous owner had the timing set up, haha - after having bought one and setting at top dead center, seems fine now from what I've seen, though!
I do have logging functionality from my ECU, I didn't get the chance to try and recreate that behavior though, but maybe someone can see something that I don't. I'll probably get he chance to get some better logging data tomorrow.
* AFR 185cc heads
* B303 cam
* Fluidyne Radiator
