oil dipstick
jonathan2000gt
i bought a 09 crown vic motor to put in my mustang dipstick snapped off and now cant get it how tried drilling it but at the angle cant get it dont know what to do
J
jonathan2000gt
Wtf are you drilling?
the plastic broke and was to tight in the tube so was trying to drill it out so only the metal piece is left and i can get it out with a magnet but wont work because of how low this *** oil dipstick tube sits
RAU03MACH
NEW MEXICO
if you have small drill bits it will work , then get a screw in it and pull out
dont go all the way trough it just enough to get it to bite
95opal
You know you can pull the entire dipstick tube right out
98snakehorse
Southeast, IA
Its hard to help with not seeing the space you are working with. Best bet is to tap out the entire housing.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
It would likely be much less headache to pull the tube out of the block. It’s one bolt on the side of the head and the snake the tube out. It’s kind of tough, but it can be done.
wbarter
