Oil Pick up tube
Newoldschool
Hi all,
Some knuckle head dropped a rock the size of a basketball and I ran it over. Could not avoid it without taking out the car next to me. It bent the k member, and smashed my oil pan. Insurance would total the car if I go that route but I can't let that happen.
Bought car about 1 year ago with 21k original miles (2004 Mustang GT Convertible). After replacing all rubber suspension components, brakes, shocks, convertible motor/cylinders, all fluids, paint correction, upgraded the sound system, installed sound dampener, window tint, added heated seats and new wheels/rims and a few other odds and ends. I drove it a full 3 months and this happened.
The front end is getting a complete make over. I have all parts ordered but I cannot find an oil pick up tube (Part:XR3Z-6622-CA or XR3E-6622-CA).
If anybody has one, Please let me know, this is the last piece to the puzzle.
Pictures of it stock and at a car show.
96blak54
Staff member
Lawrenceburg Kentucky
Im not 100percent positive with info about oil pickup tube and oil pan for your year, but I will confirm the 96-98 mustang oil pans and pick up tube are specific to the mustang, however, the other 4.6l car platforms(crown vic/town car/marquis/thunderbird) oil pans and pickup tubes will work.
A bit of info for the 96-98 oil pans and this may be the same as yours....I dont know. The mustang oil pan has a bump at the lowest area portion of the pan. This bump is for low area oil pooling and that the oil tube resides close to. Using a different oil tube end pick up are from a different platform may not reside as close to this bump indention....pretty sure it does not. A matching oil pan and oil tube from a different platform will work together tho.
Newoldschool
Newoldschool
Thank you @ 96blak54. Mine is a 2004 GT. I looked online and went to the dealership, according to both, I can only use the part numbers included in the original post. Any other models are to shallow to reach the bottom, from what I understand, the tube isn't the correct dimensions.
Ill keep looking for one. If push comes to shove, ill have to go to the junkyard and pull one. I was trying to avoid dropping a K member at the junkyard, the cars are on some shady rim stands around here.
Lucky57
