Oil pressure gauge 2001 v6
Discussion in 'General Tech' started by carbuff, Aug 6, 2019.
  1. carbuff
    carbuff Member
    167
    Oct 6, 2012
    Is it true that this so called gauge is just an on off type thing that either shows the needle at some point on the scale or no reading, with no in between? Im looking to change the sender unit and they all seem to be the same ones for a light setup with just the one wire and really small. If I had no oil pressure would there be some other sort of indicator like the cel light or audible alarm?
  2. trebor3170
    trebor3170 New Member
    97
    30
    Mar 25, 2019
    Salisbury, MD
    Yes, the oil pressure "gauge" is just an idiot light with a needle, it uses the same sender as a light, and reads either normal (middle of the range) with oil pressure, or nothing with no oil pressure. AFAIK there is no other indicator of oil pressure.
  3. carbuff
    carbuff Member
    167
    Oct 6, 2012
    Thanks for the response. I was wondering when all the sending units online were only for a light.
  4. lwarrior1016
    lwarrior1016 Moderator Staff SN95 Supporter
    5,431
    451
    Sep 22, 2014
    South Mississippi
    The best thing you can do is tee off the pressure port and put an auto meter electronic oil pressure gauge in there. You’ll have to find an extra spot for a gauge (a pillar, steering column). This way you will know for sure what your oil pressure is.
