Oil Pressure Issue
Bub
Pistakee Highlands
Okay just got done with a H/C/I swap stock rotating assembly. I have about 150 miles on the car and a hour or two of idling. I've noticed that oil pressure is good on start up (idle issues of course) however as I drive around and warm the car up. When I get to low speeds or red lights my oil pressure on the stock gauge drops to low or nothing. If I feather the gas it comes back up and when I'm driving its normal. I'm not sure where to begin looking. Thanks!
DeepList
Administrator
Auburn, IN
The stock oil pressure gauge is about a useless piece of junk. Essentially, it's just an over-glorified idiot lamp and it will either show that you have pressure, or you don't. There may not be a real issue at all.
toyman
It is important to the extent that it's a warning. The warning pressure is 6 psi. In that sense it should never come on with the engine running. I would remove the switch a thread in a gauge to see the actual pressure. If it's good (40+ psi) replace the switch.
TreeScholar
