Oil/seal issues...please help
NotQuik
Alright, bought car had AODE, always had oil leak from day one....removed trans and replaced with tremec and changed rear main at same time, still leaked. Throw out bearing failed removed trans replaced clutch (smoked it) replaced rear main again, still leaked...drove for awhile front main now leaking too (harmonic balancer went bad) removed trans again replaced rear main (Just to make sure I wasn't losing it or doing it wrong, Mechanic friend of mine did it and no scaring on crank whatsoever to just get that out) also replaced oil pan gasket this time around as well, and frpp sfi harmonic balancer too, still leaking at front and rear main. I still have vibrations I can feel as car revs up....i'm thinking is it possible for main bearing to go bad and cause play in the crank and in turn cause my vibrations/leak issues? Any help or suggestions would be great.
Motor is stock BTW, and has about 124k miles if that's good for anything and wasn't well cared for before I bought it.
I posted here because not everybody makes it to the 94-95 tech section and I wanted all input possible. Thanks
95Five0
