I was looking everywhere for that same pic to post here. THAT is how you route your belt without a smog pump. the belt length can vary depending on what pullies (like a blower or different underdrive setups) so you really should measure it yourself.
white94gt said:Ok the 2 bolts that are on the back of the heads?? My buddy just blocked off a hose that looks like it connects o a tube from the back of the pass head... Is that good enough or do i need to remove it and plug both hole???
Willis
white94gt said:So do i need to block off both holes behind the heads or the hose being blocked off good enough..
Willis
Brian95GT said:white94gt said:Ok the 2 bolts that are on the back of the heads?? My buddy just blocked off a hose that looks like it connects o a tube from the back of the pass head... Is that good enough or do i need to remove it and plug both hole???
Willis
I had this problem with the popping and just bypassed the pump. Then there is the possible seizing issue. Ask 94twinscrew about that. ;D
Willis
You can do this, and removing the smog pump has more benefits than originally thought to be. There is the miniscual weight savings, even less with a delete pulley, nevertheless, there are pounds off the car. The next benefit would be easier sparkplug access. Without all the tubes, it makes a sparkplug job around 20 min. If you have your smog pump hooked to an off road pipe, it can cause "popping" when letting off the gas. I had this problem with the popping and just bypassed the pump. Then there is the possible seizing issue. As 94twinscrew about that. ;D
Now, I have the pump deleted and the two holes at the back of the heads plugged with some bolts and RTV. I have long tubes with the EGR deleted, the smog pump deleted and I still passed emissions with a modified stock cat pipe.
Suspect said:Brian95GT said:white94gt said:Ok the 2 bolts that are on the back of the heads?? My buddy just blocked off a hose that looks like it connects o a tube from the back of the pass head... Is that good enough or do i need to remove it and plug both hole???
Willis
so u passed with no pump?! see my tube isnt connected to my headers and under the car isnt either and i pass. i wanna take mine off, but scared of not passing. what did u do to ur mid pipe? just hollow out the cats? what state?
Willis
Maximum95 said:I was going for a different solution to the holes in the back of the heads. My plan was to use the blocks that bolt back there, use my grinder to cut the pipes off of them, and then flip them over and put them on opposite sides. Boom, like a machined block off plate.
