97stanger
- Joined
- Mar 22, 2006
- Messages
- 5,880
- Reaction score
- 100
I have a buddy with a very similar situation. When he dyno'd his supercharged DOHC 5.4L F150, every aspect was spot on, but power wasnt like it should be. He would go home, scratch his head, replace fuel pump. Go back to dyno...same. Go home, replace, dyno, home replace, dyno. Even upgraded to a bigger crank pulley with same hp results....finally he tore down the engine with failed investigation. No clue what the culprit was. He suspected blown gaskets as well. Gaskets were perfect. Nothing on his end was the problem. The problem caught his eye and was totally unsuspecting. He corrected the problem and now the power is better than he figured at the first of it. The dyno graph keeps pulling to 5500rpm till the s/c belt breaks. Im supposed to be machining him out a 10rib setup when he decides he wants it.
Her is a pic of his truck
do you know what his issue was?
