Old School 331 Stroker swap. Need to figure out the wiring and HEI distributor then tomevto start it.
Randall Garner
US NAVY
What hei are you intending to use. Or have, if gm style , it just needs an ignition powered 12v lead my personal choice for a street / performance. I like to use the duraspark. Upgrade to a melonized or steel gear, do a recurve or look on you tube for locking the distributor out, drive it with a msd or similar cd multispark box. The internal module of the duraspark is the same as msd
Milford Mustang
I went with a single wire HEI from CJ Pony parts. I also had to buy a brass gear for it since I have roller cams.
weendoggy
What roller cam are you using? Most of the SBF rollers needed a steel gear on the distributor. At least both of mine did, Comp and Crane. I'd check with the cam manufacturer.
Milford Mustang
Ford performance roller cam with COBRA heads from a 94. I thought the steel gear on the distributor would eat the gear on the cam. I base this on info I read on roller cams vs stock.
natebbbb
