P/S pump pressure fitting AN adapter
CobraRGuy
Fremont, CA
Hi all,
I have a leak in my P/S pressure line and have decided to re-plumb it from the pump to the rack with braided SS hose and AN fittings.
At the pump end, I found a Russell Performance fitting 648030 on cjponyparts that appears to be correct. This has 5/8"-18 threads and an o-ring around the extended tip. Are these 5/8"-18 threads correct? The rack fittings seem easier to find.
I wanted to run this by y'all before I order it. Here's what it looks like:
Thanks, CobraRGuy
P.S. I went from $4.79/gallon in CA to $2.31/gallon in TX. Yes that's right... less than half the cost. Also, my registration went from $379 to $70.
cobrajeff96
Germany
I think you need the Hydratech HBS9405 AN-6 adapter.
Good luck with the old Ford C-III pump. I've had nothing but problems with them both original cast iron and new aluminum from Lares. It's one of those things that as soon as you break the seal and start Fing around, you find out.
RobertC
