PA Performance Starters
Twista
Is this a direct replacement on the 1994-95 mustang.
I see the 85?-1995 pa starter comes with a extra wire harness. From my understanding this is for the fox bodies with the starter solinoid in the engine bay only??
Correct??
Thanks
T
Twista
One of the connectors on the ford harness uses a crimp style connector.
The one on the PA starters just tightens up with a nut.
Sigh. Is it safe to cut this or do i need a wiring kit???
you can modify the ford OEM wiring if you need to. I did on my 2v when i put in the PA starter.
