Painted Rear Bumper
NORTON98
I already did a search and found a old post on the rear bumper being painted.
But I was just wondering if you needed to sand the bumper down and put primar and everything or could you do what Soddyrebel did and just mask it all off and spray some coats of krylon fusion (satin black) on there?
Thanks,
Mike
voidfinger
dude, if you want my honest Opin. then i would say if its worth doing its worthing doing right. Don't just spray paint the bumper.
Your talking about the bottom "blacked out" part right?
For painting that yourself you'll wanna
Mask off the rest
Scuff it up with a scotch pad
wipe it clean
then spray it
remember to cover the rest of your car from overspray, because overspray is the devil.
voidfinger
are you sure that will look good dalamar? it just sounds really bad.......spray paint and car doesn't go well together.
snoball
did it on mine and it turned out fine..
SORRY UPGRADING FORUMS, ATTACHMENT WAS ERASED, YOU NEED TO REUPLOAD!
Ya, just the bottom section looks fine. the whole bumper, I wouldn't advise.
Mine is blacked out from the factory. i'd go with a satin finish.
Just make even overlaping strokes, warm dry place, low dust, and it will turn out fine.
When you scuff it, take extra care to sand the edges and clean them really good, if you don't prep it right, it will peel there.
N
NORTON98
Ok so any sand paper will work just as long as you get the clear coat of right?
No you'll want a Scotch pad.
It's a scuff pad, kinda like fine steel wool.
Sand paper you'll probably leave lines that will show through, unless you go really fine.
Scotch pad's work well and it goes quicker.
Also, you're not sanding off the clear coat, you're just ruffing up the surface.
This gives it a clean and "scuffed" area for the new paint to stick to.
N
NORTON98
So how long ill it take for each coat to dry before I put another one on?
15 minutes?
Mike
i'm glad mine came like that from the factory...
SoddyRebel
i just cleaned it really well and sprayed the krylon fusion....
voidfinger
looks pretty good. I don't get why some didn't come from the factory like this.
94darkhorse
Idawahio
Mine is chipping away and I was going to just get it painted, although I may just try the Krylon Fusion stuff and see how it turns out.
whty98
I did mine awhile ago, I sanded down with different grits (went really fine) to below primer, then shot with Dupli-Color. You should also do a clear coat and shoot the clear over the new black paint and the stock white because that will prevent it from chipping off, then sand with a super fine grit when done w/ the clear
marktuck99
