Passing TX emissions/eng lean issues...help please...
TX_Snake
Dallas TX
My car is having trouble passing emissions in TX. I could use some guidance from the collective wisdom here....
Most recent inspecting report from this past week indicates a well running car minus a failure at high speed test for NOx. Prior to this test I have replaced (all since april) plugs, wires, cap/rotor. All oem spec parts from O'reillys, no performance parts. I recently installed new flowmaster 2.5" mini cats as well. maybe 150mi on the cats. Using a friends Matco Monitor 4000 Enhanced scanner, I retrieved the following codes last night after driving home approx 30mi hwy in 107+ temp.
KOEO
564- Fan control circuit failure KOEO ( I do hear both fan speeds come on during the test though...)
181- Fuel system at rich adaptive limit at part throttle, system lean B1
186- Injector pulse width higher than expected (with BARO sensor) (BARO=barametric psi?)
189- Fuel system at rich adaptive limit part throttle, system lean B2
KOER-PASS and Cylinder Balance Test PASS
After some google fueld semi professional amateur guestadiagnostics, I replace my O2 sensors with NTK sensors as a place to start.
Drove home tonight, same mileage, approx 90* temp and pulled the following codes.
KOEO
564 2x
SEPARATOR 10
Keep alive memory codes
181 2x
I then ran the fast codes option on the scanner and came up no codes. Re ran the slow code option and got a KAM codes PASS...which I thought was strange...
KOER codes were
172- Lack of heated Oxygen Sensor (HO2s-1) switches, indicates lean B1
136- Lack of heated Oxygen Senosr (HO2s-2) switch during KOER, indicates lean B2
CBT PASS
I will clear the codes in the morning and go drive the car since I have not cleared the codes since installing the O2 sensors.
I know high NOx is caused by high combustion cylinder temps, and I clearly have a lean eng condition, but I'm not sure how to correctly identify the exact cause.
TX_Snake
TX_Snake
Dallas TX
TX_Snake
TX_Snake
Dallas TX
Finally found the root of my problems. The MAF sensor had a low voltage output, indicating it was not functioning correctly. R/R the MAF sensor and reset timing to 10* from the 18* it was set at and now the car runs crisper, pulls harder ,and passed the test.
TN95gt
