Boostr1
Do they make a quick release elbow for our PCV valves.
What are you trying to accomplish exactly?
Throw a catch can on that PCV valve. You'll be shocked what it catches. I was. So much is now not being recirculated back into the plenum. The throttle body will thank you as well as the entire upper intake and plenum as it won't get gunked up now. Catch cans are a cheap investment and one of the first mods I'd do on these motors. I'd get one with a quick drain valve for ease of draining. I do it every oil change and I'm absolutely SHOCKED each time at the blow by.
Use the proper lines if you do it. Using improper lines will cause them to collapse and that isn't good if the PCV isn't venting properly. You do know it needs to vent right? Not trying to be insulting - just trying to help.
